westozmonaro Offline
#1 Posted : Saturday, 19 September 2009 10:59:58 AM(UTC)
westozmonaro
are the turbo 350 and 400 auto box,s the same size and use the same mounting crossmembers
have a hk with a t350 , and eh with a huge tunnel and t400
can i do a straight swap over
am putting all the t400 gear into a new eh shell and want to modify the tunnel as little as possible ,
will a t350 fit into the standard eh auto tunnel
will the t400 fit into the same hk tunnel ok to replace the current t350
jabba Offline
#2 Posted : Saturday, 19 September 2009 3:15:19 PM(UTC)
jabba
The cross member mounting is slightly different. Also, the T400 uses and electric kickdown where the T350 uses a cable kickdown.
HK1837 Online
#3 Posted : Saturday, 19 September 2009 5:29:37 PM(UTC)
TH400 is longer and bigger and heavier. TH350 is an easy fit into HK-HG, TH400 requires some floor/member surgery.
