i have an lj torana with drums all round whats neaded to get disks on the front thanks
Stubs, discs, calipers, brake hoses, master cylinder, booster and I think front brake lines. Not sure about rear wheel cylinders in LC.
Add to that:- booster mounting & relay lever set-up, as well as rear cylinders & rear brake shoes to match.
Dr Terry. |
Does the proportioning system need changing to suit changing to front discs.
James
You only have to be in front at the end of the race. |
now i have a list anyone have any parts for sale..............
