Was the Bathurst tank in the HK and HT taller or wider. I ask this as i bought a top section boot mat form my HG 350 and it does not fit.
Carpe Diem |
Carpe Diem |
It was taller.
It cant be made much wider than the standard, it just fits between the frame rails as it is.
Also AFAIK, the 350 manual HK/T/G boot mat is 2-piece.
Dr Terry |
Thanx Doc, I got a two piece but the top must be for Bathurst tank. FYI I have a powerglide HG 350 GTS and I am assuming that they also had a two piece
Carpe Diem |
Carpe Diem |
The 350 auto does not have the "Bathurst" tank, it has a standard tank and uses the standard mat.
Warren
Thanks Terry and thanks Warren. I assumedthat i was given the wrong mat, but wanted to check here first
Carpe Diem |
Carpe Diem |
