#1 Posted : Friday, 13 November 2009 9:25:21 PM(UTC)
Hi all
I have a Commodore battery terminal in the G and its stretched to buggery and won't stay tight.
Is there a way to fix it or pack it out off the terminal with another piece of metal?
I'd like to avoid replacing it if I can as it looks all factory and all.
If it were to come lose on a test drive, would it cause the engine to cut out momentarily??
#2 Posted : Saturday, 14 November 2009 3:52:40 AM(UTC)
jerermy, i put a screw between the terminal and the plug once to hold it tight, it lasted about a week and the screw corroded and it became loose again
just put a new one on, its the best way
