#1 Posted : Tuesday, 1 March 2005 7:51:54 AM(UTC)
my barina has had a little problem changing gears and in the instruction manual it says to press clutch in entirely then release and redo then put into gear , does anyone know if it has a hydraulic clutch ??
#2 Posted : Tuesday, 1 March 2005 8:45:18 AM(UTC)
Cable clutch. Adjust the plate on the floor under the gearchange there are 4 nuts you have to loosen slightly so you can adjust it. But make sure it is adjustment and not a stuffed clutch
