Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Hi A friend is looking for a front clip (subframe only) which is straight for an HK.I am looking around here.... bloody scrappies have been right through the NSW North Coast! I told him he should be prepared to anything up to a full car. He is in Brisbane. At this point I dont think it is an issue if it is an HK-T or G subframe. Any info would be greatly appreciated. Pls PM me or call 041 761 5648. I'll pass info on and put you in touch. Thanks Nick Moran. Edited by user Wednesday, 13 January 2010 7:37:58 PM(UTC)
| Reason: Not specified |
"HOLDEN MONARO. OUT TO DRIVE YOU WILD!" |
Nick
Ring Greg on 0249598999.
Byron
Thanks for the heads up Byron. I spoke to Greg today and he has a double headlight subframe ans a couple of single rad supports so he may be able to help Regards Nick. |
