Hi All, I was wondering if someone can help me. I have a factory built HT Premier with 307 chev, build No 14A. This is a geniune GMH fleet car, personel managers car at the time. I was told his name was Roy Hawke (not sure if spelling is correct). Would like to know if anyone has more information on this car - obviously being 14th car built, but could it be the 1st V8 premier??
I am restoring it currently, not going overboard, just tidying it up. Ill post afew pictures when finished.
Regards - Bill
If its Adelaide build and 14-A on the BODY plate then its the 14th V8 HT Premier built in that plant. If the chassis number is HT00014A then it would be a good bet that its the first V8 Premier, if not maybe the second. If you send mee the ID ill have a good look at it and pass it by Ben Stewart as well. Sounds like a very good car to own as well!
Hi HK1837, Thank you for the reply. Ill email you with some details on the car.
Thanks again - Bill
