#1 Posted : Friday, 15 January 2010 4:47:45 AM(UTC)
is a intake manifold gasket on a VN easy to change? the gasket on my sister in laws VN is leaking water, any tips for doing the job?
1962ekwagon Offline
#2 Posted : Friday, 15 January 2010 5:01:53 AM(UTC)
1962ekwagon
Check out the Just Commodore website. Im about to tackle the same thing on my VS & they have some good write ups on everything commodore.
#3 Posted : Friday, 15 January 2010 8:04:32 AM(UTC)
Assuming V6, not hard at all. Just be patient & remember where all those wiring connectors go!
A tip before you start - run the engine & pull out the fuel pump fuse (not the relay) this will reduce the pressure in the fuel line a bit, so theres less risk of a big spray when you disconnect it.
Also, drain the radiator coolant to about 1/2 way down the radiator, so you minimise the amount that will fall into the valley, and change the oil once youve completed the job.
#4 Posted : Sunday, 17 January 2010 4:55:30 AM(UTC)
thanks mick, will i need to use any sealant on the gasket or just put the gasket/s in as the are
BTW yes its a V6
#5 Posted : Wednesday, 20 January 2010 2:53:23 AM(UTC)
My Wifes now departed VP used to leak coolant from the front of the inlet manifold near the coil packs.
Tightening the inlet manifold bolts fixed the problem in 5 minutes as they were not overly tight.
Might save you some stuffing around.
Vandals and graffiti "artists" do everyone a favour and target parking meters and fixed speed cameras only.
