Fastlane
Holden Forums
Holden General Discussion
Difference between Low Compression & HC red motors
What is the difference between Low Compression and High Compression red motors. Did holden produce the compression difference using different pistons or different heads or some other means?
The difference is in the head. It is quite easy to tell them apart on a 6 cyl...look at the passenger's side of the head near the back and there will be a circle cast into the head with an L or an H in it. The L stands for Low compression and the H for hi
On the 186 motors the Engine Plate will also indicate wether your motor is hi or lo comp.
Now a manual or something will tell you for sure, as I am going off my memory which can fail me occasionally, but I think it was thus:
The 186P was the low c
Hi Guys.
That is only partially true.
The low comp versions of the smaller motors where made, simply by using head of the larger motor,
i.e. a 149 lo comp has a 179 head, a 161 lo comp has a 186 head & a 173 lo comp has a 202 head.
A lo comp v |
Also the low compression heads have a largw combustion chamber the high compression have half the camber filled in.
Yes johnperth, but that is only true for the smaller motors. All the 179/186 & 202 hi comp motors also have the larger combustion chamber.
Dr Terry. |
I never knew about that until I just read this thread, so ,I`ve just checked my engine and it turns out its a low comp. head, can I just put a high comp. head on it or is there more to it than that? does anything else need ro be changed as well? and also
Hi ToddBrokenHill.
You are confusing the issue by calling them lo & hi comp head.
You are better off referring to them as large chamber & small chamber heads. It depends what block they are fitted to before you know what compression you will end up |
Fastlane
Holden Forums
