Hi : Does anyone have any info and diagrams of a mechanical clutch to cable clutch conversion for an LH Torana
6cyl or V8?
Ill see what I have out of a UC book, but your best bet would simply to find a UC Torana 6cyl manual and tke some pictures. Youll need a 6cyl UC manual pedal, cable, bellhousing, clutch fork, throwout bearing anddrill a hole in the firewall in the same place the UC has one. I think a smaller hole is already in the right spot on an LH, you justhave to enlarge it. VB and mid HZ onwards also have the same bellhousing you need.
