#1 Posted : Sunday, 22 August 2004 6:12:27 AM(UTC)
Hello All
Okay I know that alloy heads have valve seat inserts, however a 3.3 XF head, would this have hardened valve seats as standard so ULP can be used without any upper cylinder lubrication?
Regards
gts_hg
#2 Posted : Monday, 23 August 2004 1:06:22 AM(UTC)
what year is it?most of 86 and all 87 xf's had unleaded motors anyway
#3 Posted : Monday, 23 August 2004 4:25:25 AM(UTC)
Hey, what about the XE engines, cause I've been running mine on normal unleaded. Is that good? I thought all the alloy headed X-flo's were unleaded!
#4 Posted : Tuesday, 24 August 2004 5:12:55 AM(UTC)
3.3L was LOW compression and should run on unleaded. All alloy heads will have steel vavle seat inserts. Unleaded petrol was introduced in Australia from the beginning of 1986
#5 Posted : Wednesday, 25 August 2004 9:16:30 AM(UTC)
i thought that pre 87 engines should be run on LRP/Super, but aslo can be run on Ultimate-98 Octane, as long as it has Valvesaver n it?
thats the theory im running with in my Zk nehow.....
