Hey lads,i had a question posted about the hg fuel tank and i was asaked if it was a fourspeed etc and that it might be a bit rare.Could any one please help decode it please. HG 38071B MODEL HG80480M BODY 15280B TRIM 180210E PAINT 56812207 long skiny plate 80480gh189911 firewall no hg38071b again thanks for any info you can give me,mono Edited by user Friday, 19 March 2010 9:59:14 PM(UTC)
| Reason: Not specified
Thanks: 1 times Was thanked: 603 time(s) in 570 post(s)
That just tells you it was a V8 HG Kingswood ute. Good start.
As it has the Salisbury hump it means 308.
So now just look to see where the speedo cable goes through the firewall (towards centre or drivers side). Also check if it was a floor shift or column. And look at the passengers side floor, where the floor, tunnel and firewall converge, about where the passengers right foot goes. If there is an odd looking hump there with all ripply metal, that is a Saginaw hump. Also check if it has bucket seat mounts.
Should look like this if its a saginaw manual.   Reality is only an illusion which occurs due to a lack of alcohol.
hey thanks for that,yea the speedo goes as per your picture and its a floor shift with hump as your photo and yes it has holes to mount bucket seats each side .thanks for your effort,mono
Well then, Ill leave it to those who know to suggest potential value. But, if it was mine Id restore it back to dead stock, wouldnt worry too much about the colours its a commercial vehicle and liable to be a bit on the bland side. It will be interesting to see what the colour and trim is, you might be lucky. Reality is only an illusion which occurs due to a lack of alcohol. Edited by user Friday, 19 March 2010 8:00:30 PM(UTC)
If any body has the time can they break down the id numbers pls,so i know as much about the ute before i decide weather to do her up.colors etc.thanks mono
12207 is Marina Blue (which is a light blue similar to http://gallery.oldholden...t+Colours/HQ/Frost+Blue/) and 10E is Black vinyl trim You appear to be a number short in the Vin Nice find though Leroy "Planet earth is the asylum to which the rest of the universe sends its lunatics" Voltaire |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
yea sory vin number is 80480gh189911.thanks for that,mono
Well then you have a 308 Saginaw HG Kingswood ute with buckets. Very rare car. If you ever wanted to do up a HK-HG ute this or its HT equivalent would almost be the one. Only HK 307 4spd might eclipse it. As for value, Id clean it up and stick it on Ebay if you were going to pull it apart. Unless you want to fix it up and keep it!
any other thoughts out there boys,the body is in fair condition.any thoughts would be welcomed,thanks mono
drive it, and enjoy it!
restore it back to original. a very rare ute. just my thoughts......
Its a Brisbane car as well.
You only have to be in front at the end of the race. |
just drive it and enjoy it
