hey lads,i am in the process of a full resto on my hg coupe and its a six cyl body.my question is i have a hg ten bolt and a 12 bolt diff that i am decideing wich one i will put in. 1)whats the difference between the two diffs 2)will either of these diffs fit and clear floor and fuel tank or will i have to put gts tank and fuel hump in the floor(where tank botts up front edge),thanks for any help,mono
10 bolt will fit easily. Hump was designed to clear the 12 bolt. Is it an original HK-HT 12 bolt or a Camaro one? 12 bolt is a lot bigger diff.
how do i tell if its an original hk-hg 12 bolt.is there some markings to look for,thanks for the help,mono
Brakes and stud pattern. Ill find out what else.
Ive got a 12 bolt in a Transam,and mate they are really big(as Byron said),I think for what its worth just use the 10 bolt and keep the 12er for a bigger project,unless your putting in a "REALLY HEALTHY" motor...just an opinion. Jim in Adelaide...Hindsight is bad vision! Edited by user Saturday, 27 March 2010 6:34:19 AM(UTC)
| Reason: Not specified |
Jim in Adelaide.. |
Byron, was there many HK/HTs fitted with 12 bolts(i guess only 81837 manual) Cant remember ever seeing one but everyone tells me you forget things when you age. Dave
The difference between good and great is the extra effort |
yea lads it has hk ht hg stud pattern.what will i look for as far as brakes go, HK1837 thanks mono.
Radius rod brkts or signs of them ever being there and (guessing) spacers on the outside of drums 3mm thick.-
HK 1837 or HT 1837M were optional. How many made - bugger all? I remember reading that the Beechey HT was ordered with one. Mono, if you ever want to sell it let me know. I will be putting a 450hp 427 into my HK GTS327 and a 10-bolt wont handle that. I do have an original XY GT 9" that I pulled out of my red GTS327, complete with GT brakes that I was possibly going to use if it has 31 spline axles. It is a 3.5:1 LSD. _______________________________________________________ If we all had the same (good) taste, who would buy all the Fords? |
