YetAnotherForum.NET Help
mono Offline
#1 Posted : Monday, 29 March 2010 2:09:24 AM(UTC)
mono
hey probs a silly question but im trying to work out the ratio of a 10 bolt diff. took backing plate off as i could see no numbers on flange seal cover(was told sometimes stamped there)and only numbers i could find are.
3790628 11;37 GM 5-68 2 these numbers are on crown wheel.
can any one help out here please? thanks mono.
Edited by user Monday, 29 March 2010 8:51:25 AM(UTC)  | Reason: Not specified
#2 Posted : Monday, 29 March 2010 2:17:33 AM(UTC)
look on the crown wheel (the big cog ) should have ,,,,,ie,,,,3.08 they are all stamped,you may have to turn it around to see it.if its not ,you will have to calculate the old way.
mono Offline
#3 Posted : Monday, 29 March 2010 2:26:39 AM(UTC)
mono
yea na the numbers i have posted are the only numbers on the crown wheel,can you explain again the old way of calculating,turns per wheel equals turns at rear diff pinion?
#4 Posted : Monday, 29 March 2010 3:21:41 AM(UTC)
Open-Style Differential - You MUST leave one rear tyre on the ground if if you have an open differential.
* TURN THE REAR WHEEL.
* Count the number of times the driveshaft spins for every TWO revolutions of the wheel.
* This number (including fractions of turns) is the gear ratio
ie like a clock 3 turns of the tailshaft =3.00
3 and a 1/4 turns is like 3.08
3 and a 1/2 turns is 3.55....and so on....ok?
ITCH Offline
#5 Posted : Monday, 29 March 2010 9:05:52 AM(UTC)
ITCH
or just divide the number of teeth on the pinion into the number of teeth on the crown wheel, easy and most accurate way.
CHHERS!!
< Gotta Luv It!
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
antoni Offline
#6 Posted : Monday, 29 March 2010 9:15:48 AM(UTC)
antoni
Hi with that part no ending in 11,37 would be 3:36
Tony
bazza30555 Offline
#7 Posted : Monday, 29 March 2010 9:09:45 PM(UTC)
bazza30555
Early chev not aussie, mine has 12 37 = 3.08. John.
mono Offline
#8 Posted : Monday, 29 March 2010 10:17:00 PM(UTC)
mono
thanks heaps lads,done the wheel rotation and the division method and came up with 3;36.thanks again, mono
