If you undo the clutch pedal - pull the clip off & slide the pin out - it makes it so much easier to get the whole lot in.
You'll need to drop the column down - 2x 13mm nuts from underneath that hold it up to the dash brace, and there's a bolt through the bracked into the pedal box frame near the pivot points.
Then you need to undo the 2 bolts on the firewall side, either side of the clutch hole (they have access holes in the firewall mat). Back inside the car, undo the clip off the brake pedal rod, and pop the rod off the pin on the pedal. Then, also from inside the car, undo the 2 nuts holding the brake booster in - you don't need to remove the booster, but those nuts hold the pedals against the firewall!
The hardest bolt to get to is the 13mm one that's mounted vertically at the top, bolted up into a captive nut in the dash brace, above the steering column. Take this out last.
Then when you have the new pedals sat in place, fit that bolt back in loosely to hold the pedals in, and fit all the other fasteners - the 2x nuts on the booster, and 2x bolts from the firewall side, before you start tightening them all up. Then refit the brake pushrod, and the clutch pedal, before lifting the column up into place & fitting the 2 nuts to the brace, and the bolt to the pedal frame.
It will all make more sense when you have your head under the dash.
Also, do you know how to pull the RH corner of the dash out? You'll need to, to give you enough room, and it has to be done first....so I'd better explain it. When you've undone the lower steering column shroud, loosen the 2 column holding nuts, and you'll be able to see the 2 phillips screws going up vertically into the dash brace, that holds the column end of that dash part in place. Undo them. Pop the headlight switch out, and undo the screw vertically above it (not all cars have this screw). Then pull the vent inserts out of the RH A/C vent, and undo the 2 phillips screws in the top of the vent - tip: turn the vent to "off" before you undo them, so the screws don't end up down the A/C ducting. Undo the final screw, under the lower corner of the dash (near the kickpanel) and it should drop away. You can unplug the wires off the locks/windows circuit breakers & kiddy lock buttons (label the wires, as they need to go back exactly the same way). Also unplug the dash light dimmer wires. Have a look at the fuse box, and you'll see the 'legs' that hold the fuse box onto the dash piece - bend them in to release the fuse panel, and you can pull that whole corner out of the car, giving you enough working space to do the pedals.
