Could any one decipher these numbers...4 speed manual t806599 and t2337...186 engine 186p400959...186 engine 186p148804.The compliance plate says...eng L20 trans M22 r axle GM9. Many thanks Peter.
No idea about the boxes. The 186's are HK-HG high comp engines. First one probably HG but is an awful high nuumber, the second one most likely HT. L20 = 202 high comp in HQ-WB M22 is wide ratio 6cyl aussie 4spd in HQ-WB GM9 = 4.44:1 Salisbury. The BODY plate in question can only be off a 6cyl 1973 onwards 1-tonner.
