Hi I am converting a HZ premier from auto to a manual. I have a HZ 8v clutch pedal, cable support bracket and a manual brake pedal. Can anyone please inform me where on the firewall the clutch cable has to come and how and where the cable support bracket is fitted... thanks
Andy
Is it a full cable clutch setup or a half cable, half rat-trap? PM me and i'll send you a scan of how it goes together.
It is a full cable clutch thanks _______________________________________________________ If we all had the same (good) taste, who would buy all the Fords?
_________ CAn you also tell me where on the firewall the cable need to come out thanks
if we all had the same (good) taste, who would buy all the Fords?
Tell me which type of clutch setup it is and I can send you a picture.
From what i can see i thibk it is a full cable set up...Im not sure what a half cable set is or look like
