ccbutton Offline
#1 Posted : Thursday, 8 July 2010 1:20:52 PM(UTC)
ccbutton
hi every one
after spending a hour or so i have no idea how to remove the old cassette head unit outta my VK commodore, can someone please tell me the easyest way please????
thanks
Speed is just a question of money... how fast can you go?
#2 Posted : Thursday, 8 July 2010 4:54:58 PM(UTC)
You need the special tools to slip down the sides to "pop" the catches on either side of the unit.
And..... You literally have to remove most of the RH side of the dash.
They are fitted with an anti-theft plate, which is screwed into the cross-brace of the body shell, and requires you to remove the instrument cluster, binnacle, and centre A/C vent ducting to access the screws.
Lift up the touch switches from the back edge first, then unclip them.
Undo the screws above the cluster shroud, and behind the touch switches, then pop it out (it's clipped in along the bottom edge).
Remove the lower cover near the pedals, so you can reach up & unclip the speedo cable (you may be lucky & get enough length in the cable without this step, but be aware of it.
If you can, try to bend the centre A/C ducting up out of the way, and using a stubby phillips head screwdriver, undo the 2 vertical screws holding the plate at the back of the radio, to the brace.
You'll then need to try to undo the nut on the back of the radio, to release it from the bracket as well - this is really difficult unless you have tiny hands. A torch & a mirror would be your best allies here!
Once you have removed the security bracket, you need to pop the eurovox tools down each side of the radio (the holes in the side clips are a guide - you can make your own from sheetmetal, in an "E" shape - but make sure you form a pointed end on the centre bar of the E, as this is what releases the side clips. The bars of the E need to be about 3-4 inches long.
To post up step-by-step dash removal instructions would take me a week of typing, so the best advice is to get hold of a service manual if you're unsure.
ccbutton Offline
#3 Posted : Thursday, 8 July 2010 8:13:39 PM(UTC)
ccbutton
thanks for that mick i shall go and give it a crack
thanks
ccbutton Offline
#4 Posted : Friday, 9 July 2010 2:14:19 AM(UTC)
ccbutton
btw mick what do you mean by the "touch switches"??
#5 Posted : Friday, 9 July 2010 3:44:25 AM(UTC)
The touch switches are the row of switches above the A/C vent - the demister switch is up there.
ccbutton Offline
#6 Posted : Saturday, 10 July 2010 7:14:50 AM(UTC)
ccbutton
got the prick of a thing outta the car today
to me 3 hours to get it out, i used screw drivers and multi grips to get it out, butchered the s*** outta it but got it out!!!!
