bortous Offline
#1 Posted : Monday, 20 December 2010 10:23:35 AM(UTC)
bortous
Up for sale is a lingenfelter camshaft that is in excellent condition and only seen minimal km. It is as new condition.
This camshaft has a stock like idle, works with the standard converter and pulls very well and hangs on in the high rpm's
This camshaft only will make approximately 270-280rwkw in an ls1, 300rwkw in an ls2 and about 320rwkw in an l98/ls3.
This camshaft has no piston to valve clearance issues.
This camshaft is also perfect for those wanting to add boost.
The specs are : 215/231 .631 .644 118lsa ($370 ONO)
for those that want a real aggressive camshaft that makes great power and don't have much concern about driveability please keep reading!
I also have other items listed below for sale that are also used, done minimal km and in excellent condition:
Yella terra roller rockers non-adjustable 1:7:1 ratio to suit ls1/ls2 heads only. These are a perfect bolt on to keep the valvetrain tight and stable if you have an aggressive camshaft. It also quitens down the valvetrain too if you have a very high lift camshaft. ($590 ono)
ls2 inlet manifold with the fuel rails (does not include injectors) to suit any ls1 engine. This intake manifold flows more than the ls1 style and will provide good airflow beneifts along with added performance. ($215 ono)
ls2 oil pump. ($90)
lingenfelter camshaft: 229/242 .631 .631 114.5lsa
this camshaft suits those wanting a very aggressive idle. It sounds very intimidating and will have v8 lovers drooling over the sound. This camshaft makes crazy power. For an automatic, you will need a 3500rpm high stall converter but will work with a 3200 at a mininum. It will work better with 3:7 diff gears or higher. Power band: 2800-6800 ($480 ono)
if you are interested in a package deal or an individual item please let me know
i prefer pick up but i will post out if required.
If you have any questions please feel free to call or text me any time on 0408481470 for the fastest response.
