Hi has anybody outthere had issues with the rare spares fuel gauge ??? I ve noticed a strong fuel smell coming from the rear of the EH after filling up, so i had a good look today and found that the new sender is leaking like a sieve through the wiring pin area,it has a plastic looking block under the terminal that is not sealing. Ive had this sender for 18 months but only been in car for 6 months . Googled the problem and found others in toranas and fords have had the same problem with the rares units . What should i do ?????? Thanks Biga064
Similar issues in this thread: http://www.fastlane.com....topic.asp?TOPIC_ID=20352Cheers, Mick _______________________________________________________________ Judge a successful man not on how he treats his peers, but on how he treats those less fortunate. |
Hi Biga064 As you can see from the link supplied by Commodorenut we did have a problem about 18 month ago which is now fixed, if you supply me with your name & address I will send you another one at no charge. email [email protected]Les
H,Iam about to buy a sender unit for my HQ Monaro have there been any problems with thme leaking at all that you know of.
Regards Tony.
What goes around comes around |
About 18 months ago we had some that leaked, the problem was solved very quickly and we have had no problems since
quote: Originally posted by les
Hi Biga064 As you can see from the link supplied by Commodorenut we did have a problem about 18 month ago which is now fixed, if you supply me with your name & address I will send you another one at no charge. email [email protected] Les
Thanks Les for the service and support . Biga064
