#1 Posted : Saturday, 26 March 2005 1:09:29 AM(UTC)
puting a vr v6 in a vh and are having problems with injector wiring.
own a vr gregory's book but it contradicts itself. i have power to the grey and blue injector wires(terminal c16 c15)and the gregory's book says it should have power and not have power when the ignition is on. Could someone tell me what it should be. with a working a v6 test if blue and grey have power with test lamp with ignition on butn not running.
crowe Offline
#2 Posted : Saturday, 26 March 2005 4:20:19 AM(UTC)
crowe
You will find that power should be at the injectors and its the negative side thats gets switched at the computer.
#3 Posted : Saturday, 26 March 2005 8:09:37 AM(UTC)
yep should be 12v+ at inj with inj ign on ecu supplys switched earth cheers chris
