Hi
Does anyone know where I can find body mounts for a HJ premier sedan?
Also looking for the the set of oil tubing (not sure of the name) that goes from a T400 gearbox to the radiator oil cooler. I'm putting a 350 SBC.
At the moment I've got the 202, which I dont think they wil reach,not sure.
are you talking about the body mounting rubbers?
Sorry, yes I'm after the body mount rubbers for my HJ premier sedan
and also the oil cooler tubes.
Im putting a T400 gearbox with 350 chev are the tubes the same as the holden v8?
http://www.rarespares.ne...tPage.aspx?product=BMK1Awe make the rubbers and bolts etc for mounting the body if your interested on the cooler lines im sorry we havent done anything for those yet im sure someone on here will be able to sort you out tho
Just use LPG copper automotive tube, 5/16" from memory and its platic coated. Get them flared to fit and run as per factory lines. |
Hi,i can supply you high quality, long lasting body mount rubbers & bolts.The rubbers are made with high quality epdm rubber & the metal washers are zinc plated to prevent rusting.I have plenty in stock.To inquire or order please email - [email protected] or phone -(07)55490351,cheers, Paul.
quote: Originally posted by hjprem
Hi
PAUL HARRISON |
