Gday all, Could someone tell me what the numbers mean after 307746640 mine is K10 16 |
Nessyhk Built not Bought |
Hi Nessy, K = McKinnon plant in Canada, 10 = October, 16 = 16th day. There's lots of sites on the www about this sort of stuff, here's one that you can try. http://www.nastyz28.com/sbchevy/sblock.php
HK Monaro engine is my guess. |
Jim in Adelaide.. |
Too many numbers. Should only be 5 numbers after the 307 and before the K. It is from a HK or HT assembled in the Elizabeth plant. If the number is actually 74640 or 74664 or 74660 it is probably too early for HK Monaro, so should be from a HK Premier, Kingswood or Belmont. |
sorry guys the original no is 30774660 cheers |
As HK1837 said, too many numbers after 307, but you've got it now and thats the car HK or HT assembled at elizabeth, the engine assembled at McKinnon....Jack
