hey, just wondering if any of you could help, i have a 06 bf xr6 magnet, i recently built my own steel + checkerplate tray to replace the beat up tub i had on it, after taking the tub off and now putting the tray on, it seems when i start the car now traction control automatically is OFF and i cannot turn traction control on at all.. would you have any idea of why that might be? thanks
Check your ABS sensors on the rear brakes/axles - make sure you haven't dislodged one, as traction uses the signal from all 4 wheel sensors, and will throw up an error if it can't read all of them. |
thankyou for your help, i will check next time im at the car
