stephenreed Offline
#1 Posted : Tuesday, 19 July 2011 5:08:46 AM(UTC)
stephenreed
I need advice on what would be the best option for a tail shaft for my HQ tonner T400-Salisbury.
I have a T400 tailshaft out of a sedan which is too short and i also have the old trimatic tailshaft that came out of the ute.
I know you can change the slip yolk from T400 to the tri-matic shaft but have heard this don't leave much play and with a good knock the tailshaft can bottom out on the back of the box and damage the g/box casing.
If i need to get another tailshaft made using my old T400 tailshaft ends what diameter tubing should i use?
Estimated 350-400hp motor (if this has any influence on tubing size)
Thanks in advance.
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
#2 Posted : Tuesday, 19 July 2011 5:23:49 AM(UTC)
Use the original 1-tonner shaft and shorten it. Tonners have bigger unis than normal (1.125", normal is 1"). The tonner diff will have a bigger yoke to suit the uni. The original TH400 yoke also has this same size uni, so once you shorten the shaft the yoke will go straight on.
dirty davo Offline
#3 Posted : Tuesday, 19 July 2011 5:26:29 AM(UTC)
dirty davo
Thanks in advance.
tonna used 3" diam tube with 3mm wall
ute/van & statey use 2.5" tube & 2.5mm wall)
i have several tonna shafts here & some th400 yolks
you need to get a measurement from diff yolk to g/box ext housing at ground height (with all four wheels on ground)
i should have one to suit.
price is $245 with yolk or $175 without. (plus freight approx $50 - $80)
regards DD
stephenreed Offline
#4 Posted : Tuesday, 19 July 2011 5:32:17 AM(UTC)
stephenreed
Sorry i should of included the following...
The diff is not a tonner diff so it only has the small uni.
The tailshaft that was in it was tri-matic to banjo.
So using the original tail shaft a viable option?
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
stephenreed Offline
#5 Posted : Tuesday, 19 July 2011 5:38:24 AM(UTC)
stephenreed
Davo,
From diff yolk to back of box is 1715-1720mm as i added the diff has only the small uni.
I if you have something i'd be interested in buying it.
Edited by user Tuesday, 19 July 2011 5:40:13 AM(UTC)  | Reason: Not specified
1970 HG Panelvan
1971 HQ 1 Tonner
2001 WH Statesman
Kawazaki KLX250SF
dirty davo Offline
#6 Posted : Tuesday, 19 July 2011 7:51:44 AM(UTC)
dirty davo
Davo,
will check thru em in morn
im sure i will have shaft to suit without you havn to pay out to shorten one. also have a tonna diff yolk to fit on your existing diff (ie 26mm diam caps both ends)otherwise youl have to fit an adaptor uni which is dearer,(ie 24mm to 26mm) (defeats th purpose of going heavy duty)
regards DD
dirty davo Offline
#7 Posted : Tuesday, 19 July 2011 8:24:16 PM(UTC)
dirty davo
[quote]Originally posted by stephenreed
Davo,
[/quote
i have 2 one tonner shafts here outa th400:10bolt & both have std V8 end (ie 24mm uni caps)on them,, so would fit straight into your tonna as is
best to phone me if interested
regards DD 0412109239
