kookaburra Offline
#1 Posted : Sunday, 4 September 2011 5:30:29 PM(UTC)
kookaburra
Mate has 1994 longreach ute, Often when driveing it just cuts out,pull to side of the road ,crank and will not start, crank more and motor shakes violantly, wait 15 minutes ute starts up as normal, Ute has new dizzy and coil but problem continues, will sit and idel for hours and not show problem, what should be checked next???
#2 Posted : Sunday, 4 September 2011 10:02:41 PM(UTC)
try new fuel filter it may be partly clogged
Paul351xb Offline
#3 Posted : Tuesday, 6 September 2011 3:49:00 AM(UTC)
Paul351xb
You are a member of these groups:: Moderator, Registered, Veteran
Mate of mine had this problem. Turned out to be one of the wires that plugged into the dizzy had cooked itself where it went close to the manifold and block. Would only show symptoms during a long run where it got hot enough for the wire to seperate a bit causing all sorts of problems. Have you checked all the wiring in the engine bay for signs of brittleness or heat damage?
kookaburra Offline
#4 Posted : Tuesday, 6 September 2011 8:36:54 AM(UTC)
kookaburra
Will do that, at present there is no spark, plenty of fuel. started 10 times during the day just sitting at work, went to go home no go again, very enoying to say the least.
kookaburra Offline
#5 Posted : Thursday, 15 September 2011 7:43:14 AM(UTC)
kookaburra
found, computer problem, going ok for now.
