monman71 Offline
#1 Posted : Monday, 12 September 2011 1:21:26 AM(UTC)
monman71
Are the upper and lower front suspension arms the same between HQ-HJ-HX to the HZ RTS?
Premier 350 Offline
#2 Posted : Monday, 12 September 2011 3:42:47 AM(UTC)
Premier 350
Thought the arms were all the same, but the bushes and upper control arm location were altered. Amongst other things.
#3 Posted : Monday, 12 September 2011 4:01:25 AM(UTC)
Yes they are the same except later lower arms have the shock hole made bigger for larger shocks.
BIGCAV Offline
#4 Posted : Monday, 12 September 2011 5:33:28 AM(UTC)
BIGCAV
is there a difference in the upper control arm pivot shaft? noticed 2 different types comparing a wb to a hq-hj
74HJLS Offline
#5 Posted : Sunday, 18 September 2011 3:26:31 AM(UTC)
74HJLS
Shocker mount on the upper control arm for RTS has a dished washer welded in to strengthen it.
Pete.
#6 Posted : Sunday, 18 September 2011 5:56:29 AM(UTC)
The upper arm is different. The shock mount is moved further back.
#7 Posted : Sunday, 18 September 2011 6:55:15 AM(UTC)
That is UC, HZ are the same as HQ-HX.
#8 Posted : Sunday, 18 September 2011 7:45:48 AM(UTC)
new Ishould have gone and looked closer before I posted that HK!
