Joined: 28/12/2010(UTC) Views messages in topic : 118
I just wan't to get in contact with an expert on monaro's,so can someone put me onto the right person as there is something I wan't to find out about mine.
Regards Tony. |
What goes around comes around |
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
Who you wish to contact depends upon which series you are talking about. And then which assembly plant. The answer will vary depending upon the responses to those 2 x questions. It will also depend upon the nature of the question: eg originality, modification, identification, trim, driveline, paint etc etc. There is a large number of people that could be the one you want depending upon the above and more. Ben, Terry, Warren, Dirty Davo, Simon, James etc. |
Its for the 72 HQ GTS Coupe and it is about paint and a couple of other things. Regards Tony. Edited by user Saturday, 29 October 2011 1:48:31 AM(UTC)
| Reason: Not specified |
Maybe try Warren Turnbull here via PM first. He should be able to point you to a HQ guru if he can't help you himself. |
Thanks Mate.
Regards Tony. |
