Could some one please ID a HZ van, it is listed as a HZ8WM40. Note sure what this model is. It currently has a HX prem front.It is a bit unusual as it is a L32, M20, GV4 with factory GTS dash, GTS guards and has a seating capacity of 2. Thanks
Thanks: 1 times Was thanked: 626 time(s) in 590 post(s)
HZ8WM70 is what it will have on it. This is a HZ Holden panel van.
253, 4spd and 3.36 is a tiny bit unusual (only because of the 3.36 diff) but not all that surprising.
GTS guards have been done post factory.
Quad headlight fronts are also not uncommon on HZ vans, they were standard on BO6, XX7 and XU3. HX grille could easily have been added later.
PM me the vehicle's full details including GVW and i'll see what I can tell you about it.
