adam PERTH Offline
#1 Posted : Wednesday, 25 January 2012 8:52:58 PM(UTC)
adam PERTH
will a 6 cyl. auto ex AU falcon fit into an ED Falcon?
#2 Posted : Wednesday, 25 January 2012 10:08:48 PM(UTC)
I have been told that they do and that the AU trans is the strongest of them all due to it's larger and noisier planetary gears.
I have also been told to try and avoid an AU3 trans as they don't have provision for the speedo sender because they got their speedo readings from the ABS sensors. That one is an easy thing to check for yourself though.
