htprem Offline
#1 Posted : Monday, 30 April 2012 4:47:01 AM(UTC)
htprem
Hi All,
I am trying to track down a couple of cylinder heads for a pair of 186s blocks that I am wanting to restore. Standard 186 heads would be fine as they look the same from the outside (other than the stickers) and I can upgrade the valves, etc to match 186s specs, but I am wanting to match the date codes as closely as possible. I have one block that is dated 6th Feb, 1970 while the other block is 19th April 1970. If anyone had cylinder heads to match either of these dates (close should be ok) could they get in touch?
htprem
Premier 350 Offline
#2 Posted : Wednesday, 2 May 2012 9:13:08 AM(UTC)
Premier 350
I'll ask a mate- did have a 186S complete on the farm several years ago.
Might still be there.
