I acquired a Rochester Quadrajet carby with some other parts. Located 17059596 and 3239 (is that a date of of 323rd day of 1969?)CXL on carby. I was advised it came from a HK HT HG. Any help in confirming what it came off / what it is for? |
Alex |
quote: Originally posted by 69 rust bucket
i may be wrong would it be 23rd 3rd 1969 maybe?
1705 - '76 - '79 9 - '79 5 - Olds 9 - auto 6 - ? should only be '7' numbers CXL - production plant code 3239 - 323rd day '79 regards DD www.bellarineclassicautos.com.au
Joined: 2/02/2009(UTC) Posts: 567  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 32 times Was thanked: 9 time(s) in 9 post(s)
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Thanks guys. The end number is definitely a 6 and not 7. So would it have been on a 253/308? |
Alex |
its off an 'oldsmobile'
Thanks Dave. Oh well hopefully somone will be able to use it. |
Alex |
It is off a VC-VH or WB 253. |
Alex |
th 6th number ("5") indicates oldsmobile. if it were an "8", that woulda been GMH 1970 onwards
That number changed to a 9 from about HZ release. |
It also has "GM" on the carby. |
Alex |
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
I put up a rochester decoder on old holden. Cant work out how to put up pics on here. cheers
