phill Offline
#1 Posted : Wednesday, 2 January 2013 9:42:13 AM(UTC)
phill
Hey Guys I have a blown Head Light on my XB, what lights are the best to use these days without changing too much to the original fit up?
Also I have an extra loose wire that comes off the three pin plug and its not attached to anything, I have them on both sides and its all original, what could they be for?
Happy New Year, Cheers! Phill.
Browno Offline
#2 Posted : Wednesday, 2 January 2013 7:28:23 PM(UTC)
Browno
when i owned my xb i fitted H4 head lights best thing i did
Drive It Like You Stole It......Drive it like you own it
Paul351xb Offline
#3 Posted : Wednesday, 2 January 2013 11:48:53 PM(UTC)
Paul351xb
those wires would be for the factory driving lights mate. They hook in through the high beam. go the hella H4. Great headlight
phill Offline
#4 Posted : Thursday, 3 January 2013 5:13:10 AM(UTC)
phill
Hey guys, the ones in the car say "Wagner" on the front/ bottom of the glass and made in the USA,these were pretty weak, thanks for the info, Cheers, Phill.
Paul351xb Offline
#5 Posted : Thursday, 3 January 2013 8:08:03 AM(UTC)
Paul351xb
Phill are they a sealed beam? If so toss them. if you want a cheaper alternative grab a set of headlights out of an XC or ZH if you can find any. They have the quartz halogen globes in them and are a straight swap over.
#6 Posted : Thursday, 3 January 2013 8:32:32 AM(UTC)
Not ZH they are a smaller quad headlamp setup. The equivalent (Rolls Royce style) LTD lights will do as will the lights out of an HZ Kingswood.
New ones are not that expensive either:
http://www.ebay.com.au/i...T-KIT-NEW-/330444143071
Or you can pay $10 less and buy a pair of not so period correct flat lense headlights from the same supplier or even a pair of sealed beam halogens.
I just did a quick ebay search for 7 halogen (as in 7 inches) & came up with 1800 items in car parts alone and about 350 of those in the left column are headlight assemblies.
A word of advice though do not get tempted to use anything brighter than 55W bulbs without wiring in a relay as even they are stretching the early 40 year old wiring and headlight switch & dimmer to their limit. Even with 55 watts per side I'd be tempted to wire in a relay. The lack of voltage drop can only make your new headlights brighter:
http://www.ebay.com.au/i...ed-12V-30A-/290838896123
Paul351xb Offline
#7 Posted : Thursday, 3 January 2013 10:09:33 AM(UTC)
Paul351xb
Sorry about the wrong info there. I thought the ZH was the same size headlight. Ooops.
phill Offline
#8 Posted : Friday, 4 January 2013 9:07:22 PM(UTC)
phill
Thanks for all the info guys, much appreciated, It's a big help with all feedback, Cheers.
phill Offline
#9 Posted : Tuesday, 22 January 2013 2:06:32 AM(UTC)
phill
Before the last post was up I had purched a set of Narva H4 lights semi seald.
I will throw them in and see how it all goes, The guys at Rares say "they have been selling those for years and that's what they reconmend"
phill Offline
#10 Posted : Tuesday, 5 February 2013 2:51:03 AM(UTC)
phill
The lights are in and I can relax driving at night now, so now I don't have to drive with my head infont of the steering wheel and squashing it on the inside of the windscreen!
The H4 semi sealed lights are so much better than the old sealed beams,
Thanks guys!
