hi, ok i know its a camira but its my work hack, problem is when i turn it off it runs on for a bit, timing is all spot on as well as idle speed etc. anti run on solenoid seems to be working, its had a carbon flush done, but it still runs on has anyone got any ideas? thanks
If it is a pre-ULP Camira, are you running it on PULP? I have a feeling the pre-ULP Camira engines need PULP and an additive whereas the ULP engines will be fine on ULP (strange as it may seem...)
Cheers...Dave
if it is pre-ULP try retarding the timing a couple of deg
Hi 2 Wild4U, Nothing wrong with a Camira I had a stationwagon for 5 years before I bought my HQ ute,the only problem is the rusting of the fire wall. Cheerio Owen
God is Dog spelt backwards.
Hi Guys.
Nothing wrong with Camiras, especially the later JE 2.0 EFI.
Which model are you have trouble with. If its an early 1.6 carby, you probably have several air leaks, causing a faster than normal idle, the single most common cause of running-o |
thanks for all the replies, wasnt expecting that. it is a jb model with the carby motor, ive been running unleaded in it., i disconnected the idle cut solenoid while the car was running, but it didnt make a difference, shouldnt that cut the car out once i
i love camiras they are a good car to play with and try new detailing and engine mods because it dosent matter two much if you stuff it up. but i love my camira and i wouldnt traid it for the world.
just wonderin if any of u guys no where i could source a body kit for my camira
they did a sport model SJ camira not sure if it was body kitted.
Country dealer team did CDT JB Camiras with bolt on flares & a rear spoiler. They were sold alongside or just after the CDT Gemini's. The Super Junk Camiras as they were known within Holden dealers when new didn't have a body kit just a nice paint jo Edited by user Friday, 7 April 2006 8:10:29 PM(UTC)
| Reason: Not specified |
Haha!!! I saw your username and assumed you would be asking a performance question about a V8 muscle car.... and then you said Camira!!
hehe... off topic I know but it was a good giggle for a Friday arvo.
Oh.. and you guys are right - nothing wrong |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
Remember the tagline for the ads for the SJ Camira's?
"Your mother won't like it!" :-))
Cheers...Dave
