Forum Rank:: Guest
i have a 308 HZ premier and i want to get cold air induction i have seen kits that go over the radiator and up to the air cleaner that seal up with the bonnet has any one see one of these or know where i can get one? i don't want to cut a hole in my bonnet because i am only 18 and don't want any more attention from the boys in blue
Forum Rank:: Guest
HI Kayl, I have just listed a cold air cleaner for a carburetor engine on ebay. http://cgi.ebay.com.au/w...iewItem&item=4551472304
Thsi may be what you are looking for. Gav.
Forum Rank:: Guest
vac cleener hose works good or u can adapt ducting from something like a vn v6
What's so funny about the name Biggus dickus
he has a wife you know know what shes called Incontinentia Incontinentia Buttocks!
Hi Kayl
Question - how much is OK to butcher the HZ Premmy ?
My preferred option (yes its major work & assuming Q-J-X-Z rad supports are the same) if its a nice Premmy would be buy a spare radiator support, and cut one or 2 holes either side of th
Forum Rank:: Guest
Kayl I think you are talking about the Brock cold air tray fitted to VB to VL carby model V8's They are about $100 from American Autos in Sydney or Rare Spares I don't think it will fit on the HZ and it needs a sports cleaner the standard one won't fit
