ht307munro Offline
#1 Posted : Friday, 7 March 2014 6:25:10 AM(UTC)
ht307munro
Does anyone know of someone / business that produces a complete exhaust set up for a HT 307 / powerglide car? I have the original ramhorn manifolds so need the exhaust from there back. Prefer in QLD. Cheers.
Alex
#2 Posted : Friday, 7 March 2014 6:27:58 AM(UTC)
I haven't seen one. We found a totally original exhaust on a HK Brougham that had been sitting in dry storage for 30 years for a HK 5litre GTS, just modified the tailpipe.
ht307munro Offline
#3 Posted : Friday, 7 March 2014 6:43:44 AM(UTC)
ht307munro
You wouldn't happen to have a picture / drawing of the complete set up? Cheers.
Alex
#4 Posted : Friday, 7 March 2014 6:51:18 AM(UTC)
I will one day when I remove the driveline from the car again. It has a totally restored driveline in it which will come out and have a 350, TH350 and 9" put in.
castellan Offline
#5 Posted : Friday, 7 March 2014 11:00:43 PM(UTC)
castellan
It's just like any other single exhaust HT-G with the muffler at the rear and the pipe comes out bending down a bit then cut off flat to the road like. one of the monaro books has how it looks.
Edited by user Friday, 7 March 2014 11:02:04 PM(UTC)  | Reason: Not specified
speed.factory Offline
#6 Posted : Sunday, 9 March 2014 2:26:44 PM(UTC)
speed.factory
Interestingly, I'd considered building a low production run of these (if it was Export to South Africa I'd be Dual Exh Like The 350 )
See if you can procure yourself an original HT/HG GMH Factory Parts Manual, it (or the HQ one at least) has the Exh system layout showing routing & where flats in the pipes were etc ... its not too hard to build your own one with U-bends, 2" pipe , a Y junction for the cross-under/behind the sump manifold eng pipe & trickiest part to procure will be the 3 stud flanges & one has the slip-on heatriser up the manifold studs, unless your Rams horns are complete studs & flanges up.If not I think Castlemain or Delows used to do the Std Chev & Larger Corvette Flanges.
The Dual exh Chev Engines(export) had the oval resonators tucked under pass/drivers floorpans (you'll see the indentations in your floorpan running back to the twin in/twin out traverse muffler.
If you have the folding why not have a mate, build you a factory twin system with a Rarespares type 2 in , 2 out traverse rear muffler with the 2 tailpipes with GMH factory style turn-downs with the end cut off at an angle with the tips cut-off perpendicular ? (I built on of those yrs back & the 307 responded nicely (Oh & to Perk up your 307 Fit a 1980 305 California Z28 Factory Cam, It'll have smooth idle,more pep,& scream like a race engine (I've got 1 here NOS ) or can give you Part # or if anyone wants to PM me (not advertorial,just know successfull combos from 40+ yrs hands on tuning,in right place/s at right time.
Goodluck with finding an original drawing, but look in an Official GMH HQ Parts counter manual that has all the replacement part no's in it & you'll see what I mean, (PM me with addy & I'll scan a page to show you,if still in dark)
The only trouble with repro full length exhaust systems is the difficulty in trucking & finding samples of some of the original Hangers & some U-clamps if concourse resto being built
Goodluck
ht307munro Offline
#7 Posted : Monday, 10 March 2014 7:59:49 AM(UTC)
ht307munro
Thanks for the reply. It is not an original V8 car and I have pretty much replaced the entire floor pan and am not worried about concourse. I just want a neat, reliable car. I have the 3 stud flanges so that is not a drama. I might go with the twin system if it is to difficult getting an original one. My engine is all done, but thanks for the offer on the cam. I would appreciate a copy of the drawing - you can email me at hktgparts at bigpond dot com. Thanks.
Alex
