MarkS Offline
#1 Posted : Monday, 15 December 2014 12:19:45 AM(UTC)
MarkS
Hello,does anyone know with the 250 Non-X-Flow Log Motor what type of Con-Rods did they have?Forged or Cast etc.Can the Internals of a Non-X-Flow be used in a X-Flow?Thanks for the Tips and Answers!
Mse
castellan Offline
#2 Posted : Wednesday, 24 December 2014 7:49:50 PM(UTC)
castellan
Same rods I do believe they are forged.
Rods pistons and crank are the same I believe.
Cam is different as to the valve order.
#3 Posted : Wednesday, 24 December 2014 7:57:52 PM(UTC)
We were going to build a 221 Crossflow a few years ago to get around the bad stroke/rod length ratio of the 250/4.1 and the gutless issue of the 200/3.3
Got as far as getting an alloy head 200 from an XF but never pulled the 221 apart to gut it.
castellan Offline
#4 Posted : Thursday, 25 December 2014 2:44:39 AM(UTC)
castellan
221 rods and crank will not fit a X flow block.
If the X flow deck height was the same as the old XR-T-W block it would be a good performer.
But even if you could work out a piston or rod to work the deck is to high.
XY on mains are bigger I think.
#5 Posted : Thursday, 25 December 2014 4:48:15 AM(UTC)
Pity we never got far enough to discover that as my brother ended up building a tough 4.1 for it.
