Hey people, I've got a question that might be difficult to answer. I have recently purchased a NOS VK EFI manifold and throttle body, it has a threaded boss in the casting inbetween injectors 5 and 6. I've never seen a manifold with this before. a pic of it is here. Any ideas what it is for? I'm thinking of drilling it out and using it for the MAT sensor (currently sorting out fitting a VN Delco ECU). http://gallery.oldholden.com/EFI_mods/DSC03165
It has these dates engraved onto the manifold http://gallery.oldholden.com/EFI_mods/DSC03166
Cheers, Mark.
Those engraved dates well & truly precede VK manufacture - GMH were still assembling VHs in Jan '84.
I don't know what that boss was used for, as I have never seen it on any VK EFI manifold I've come across. NSW had different emmissions specs & had a |
Hey Mark Nice to see you have finally got it up and running! I think you must hold the world record for cramming the most amount of wires into an engine bay that actually join up to something :-) |
In thrust we trust |
Mick, Yeah, I thought those dates were pretty early....but never took a real lot of notice.....as you can see from the rest of the pics in that gallery, the manifold and throttle body are NOS. I was going to grid this manifold up to get rid of the EGR (li
ahhh the joys of EFI :)
i don't really see that is matters which manifold you cut up ....
The VK injection manifold we put in the EH Limo has the threaded boss between 5 & 6. It doesn't go through, just like the one in your pics. It had a rubber grommet sitting in it. The manifolds do look so much neater without the EGR
If it's only a blind hole (so you don't have to plug it) then grind away! Like Sammy said, doesn't matter what manifold you chop up. There's a relatively good supply of them up here on the mainland if you evrer need more (I can get my hands on 3 of them |
