Hi, Can anyone please help me to run a diagnostic check on an 88 JE camira with an LE4 injected engine. I have not done this before so any help would be appreciated. thanks Tom
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
I think these have an 808 Delco ECU so the VN Commodore diagnostic tool should plug into the harness. Most Holden dealers will have this ability. |
This isnt something that can be done at home? I had a feeling that you could get a readout from the flashes from the ECU?
Yes, but you will need to find someone with a Camira book. Have a look in a Gregory's manual. |
