G'day,does anyone know if there is any difference between GTS and non GTS door trims on HK monaros? Thanks in advance
GTS have carpet on the bottom.
Warren
Thanks: 7 times Was thanked: 11 time(s) in 11 post(s)
...was it the HK GTS that had the "GTS" badge in the door trims...or the middle of the back seat?...??
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
I think HK GTS has a GTS badge in the centre of the back seat, but not on the door trims. I believe there is also a metallised plastic strip in the door trim, which the standard Monaro may not have. HT and HG have the GTS badge in rear seat and also in the door trims as well as the Monaro script embossed in the door trim vinyl.
Warren
Thanks Warren,I thought that was the case.I just needed someone like you or Ben to confirm it.thanks to all.All the best Edited by user Saturday, 23 May 2015 8:07:57 AM(UTC)
| Reason: Not specified
Warren
Hey Warren, you wouldn't have any photos of a non GTS door trim would you? Do they have any heat pressings on the bottom or are they just plain? Thanks
From memory they are just plain, but have a sonic weld just above the "carpet line".
You should be able to buy then from the people who make the GTS door trims, just ask for no carpet.
Warren
