Fastlane
Holden Forums
Holden General Discussion
Tech Tip # 2 - my HQ/HJ Dash lights are on !
You are a member of these groups:: Registered
HQ/HJ owners. Ever driven home in twilight or dusk and cant see your gauges ? The easy way out is to replace the globes, eh ? Maybe get rid of those silly plastic shrouds ? Nah – I can do you one better. And keeps it lookin original.
Spend $3.00-$4.00 in a Model Shop and by some TAMIYA Blue Clear Acrylic paint. Borrow some clothes pegs, four is all you will need.
Remove all 4 shrouds and all 4 globes – no need to increase candle power and melt plastic anymore.
With a shroud in hand, remove the blue plastic lens. Use a sharp knife and watch the fingers. Sorry the blue lens’ gotta go. Put em in a safe place if you are worried. Then use the blue clear paint and paint over the silver reflective paint. So you get a shiny blue effect on all 4 shrouds.
Next ! Mount each lamp in a clothes peg. Give the lamps a liberal coat of Blue. Don’t get the paint on the connectors. Let the paint dry overnight. It will harden nicely in a few hours anyway. Wash the brush in acetone/thinners.
Come the morning, put all the lamps and the shrouds back. Wait for night fall !
This has worked for me...and I don’t need to squint anymore. The effect is great and not too bright with a subtle blue tint.
If you hate boring old HQ BLUE backlight for your gauges – TAMIYA make CLEAR ORANGE, RED, and GREEN as well. The colour choice is yours !
If you buy enough colours you can use the paint to change those Bunning Christmas lights from boring old white ones to multi-coloured.
Cheers, John
You can also get bulb covers from repco / supercheap. come in range of sizes and colours, and just slip over the bulbs. Have the added advantage that if the bulb is still a little bright, can slip another cover over. |
__________________________________________ Keep the shiny side up, and the greasy side down. |
Do we have another modeler on board ? Webby- about 160 GM models so far
Cool Jabba - I knew of the coloured condoms but not the size. And yes Webby a modeler from the ancient days when 1/72 Airfix kits were 55c each. Cheers...John
First time I drove home at night couldn't see anything, not helped by having a couple of illuminated aftermarket gauges up front. Solution will be very handy, though I suspect our toddlers may have some other ideas about what to do with bulbs, blue paint
Fastlane
Holden Forums
