Gerard Offline
#1 Posted : Thursday, 16 June 2016 8:39:01 PM(UTC)
Gerard
Interested to know if any of the parts shown in the following photos are available:
First photo - Part 1 - Clips to secure the left and right hand ends of the boot moulding. Haven't found them in Rare spares catalogue?
Part 2 - Wiring harness original style bayonet/socket type connectors, if available?
Part 3 - Original style Utilux terminal connectors, if available
Part 4 - Plastic style wiring harness connectors
Second photo - Tramp rod retainer piece - need one only, new or used
Third photo - Original style battery terminals
Also the original terminals on the wiring harness and battery lead to the starter motor
Gerard
Tour Director Offline
#2 Posted : Friday, 17 June 2016 10:16:11 AM(UTC)
Tour Director
You can check out the following Rare Spares parts:
BMC1023 is the moulding clip set HK Boot lid. It doesn't have the ends you are after.
H1213 is the complete Tramp Rod set, as the factory doesn't supply just components.
EC1002 is the wiring terminals that may help.
Vintage Wiring Harness in Croydon Vic may be able to help with some of the remaining parts you are looking for.
Gerard Offline
#3 Posted : Friday, 17 June 2016 6:46:04 PM(UTC)
Gerard
Thanks for these details, will check the Vintage Wiring Harness for the terminals
Gerard
hk350 Offline
#4 Posted : Saturday, 18 June 2016 1:14:02 AM(UTC)
hk350
For any wiring call Aaron at All Auto Recreations on 0418 556 677, he can replicate KTG harnesses. And for repro spring ring battery leads email Andre from ReprosRus, [email protected]. I had a set made up and were top quality.
#5 Posted : Sunday, 19 June 2016 12:52:59 AM(UTC)
For the boot lid trim I'm using these purchased from USA eBay for $2.20 each they also have a website - www.althafastener.com
Fits the GTS moulding nicely and comes with mastic sealing washers that squash flat and seal the hole.
Speed nuts also have the mastic sealing washers and look as per original.
Thread is a bit long so I'll probably cut it to size and then zinc plate them.
Edited by user Sunday, 19 June 2016 10:36:55 PM(UTC)  | Reason: Not specified
