Sully308 Offline
#1 Posted : Friday, 4 November 2016 8:00:44 PM(UTC)
Sully308
Just installed 253 with trimatic in my Q bought a tailshaft seams to fit well but rubs on every little bump..Help!,,,
Edited by user Friday, 4 November 2016 8:06:04 PM(UTC)  | Reason: Not specified
#2 Posted : Friday, 4 November 2016 8:36:51 PM(UTC)
Where is it rubbing? I can't say I've ever had a HQ-WB tailshaft rub anywhere. What diff? Is it lowered at the rear? Is the rear engine mount broken?
Sully308 Offline
#3 Posted : Friday, 4 November 2016 9:03:09 PM(UTC)
Sully308
Rubbing At every bump on the road the first uni joint, has about 10mm clearance currently, not lowered and has a 10 bolt diff, thought it may be the wrong tailshaft??,
#4 Posted : Friday, 4 November 2016 9:22:50 PM(UTC)
Is the crossmember bent? Or pushed up?
#5 Posted : Sunday, 6 November 2016 3:01:04 PM(UTC)
You shouldn't be getting 10mm movement there unless either the rear mount is broken, you haven't bolted the mount to the crossmember in the centre or haven't bolted the crossmember to the rails at the sides
8D11PCH2 Offline
#6 Posted : Sunday, 6 November 2016 3:56:20 PM(UTC)
8D11PCH2
Those transmission xmembers in the HQ - WB's seem to flex quite a lot.
