Hi, What is the purpose of tramp rods? Why are they illegal? Do you need them? Is there an alternative? Thx, Nikki
Tramp rods are to reduce the amount that the rear suspension and axle twists when you give the car a bootfull. They are meant to give you more traction and are only used on cars with leaf springs on the rear.
AFAIK, they are illegal for road use becaus
Hi, Does that then mean with them on that you would put less stress on your diff? Or uni's? Thx, Nikki
The only legal alternative is the factory tramp rods like the GTs had. Rather than hanging them off the bottom of the diff the factory rods attach via the upper U bolts on the nine inch and then a rod extends forward and up where it bolts into the subfra
Hi again Nikki, As Dave states, they're illegal because the regulations state that the lowest part of a car (APART from the rims and brake backing plates) have to be X mount (it used to be 4 inches or 100mm. 10cms for those in the ragtrade) These bolt-on
Hi Steve, Thankyou very much. I didn't understand sober but after a few bourbons I too got the gist. (Only joking). I actually understand now, so thanks. Thx, Nikki
Hi Steve,
Well explained mate...I have been trying to work out how to explain that for a couple of days now and couldn't work it out...
Cheers...Dave
the factory tramp bar that Paul mentioned is a better option to the after market tramp rods it will dramaticly reduce any axle tramp [ shudder ] that you might be getting on take off and so has to reduce the stess and strain on the running gear as well a |
old B`s go hard . new B`s have air. |
Can you still get those things? I had them YONKS ago and ended up getting a defect notice by the boys in blue. I could'nt understand back then how auto shops can sell them with regulations saying there illegal? I was pissed off like Schapelle Corby would
hi afordable i take it you are thinking of the after market tramp rods that were all the go in the 80`s . they bolted on below the diff and stuck out the front below the spring like a dogs ..... and were about as usefull. like a lot of things you can b |
Dave, some of the Fairlanes and I think all the LTDs had the tramp rods too but it was longer than the sedan/coupe ones. Both types pop up on ebay from time to time. They were also standard on the Landaus. The XAs had them too. I think they are sligh
Maybe just maybe the anti tramp rods of an XE onwards sedan can be fitted to the leaf spring Falcons. They are cheap and easy to get hold of.
I have never tried this but picked up an XE diff with all arms for free at a swap meet because the "s
Yes! I was under the impression of the 80s type thingies! I just jumped to the end of the posts to voice an opinion. Sorry I didnt know there are other kinds around these days! Hope they work!
ok need help here lol, I have a zk fairlane, auto, and when I put it into gear it takes the power, now why would that be???
quote: Originally posted by Deb
ok need help here lol, I have a zk fairlane, auto, and when I put it into gear it takes the po |
ZL Fairlane upper rear trailing arms shoulb be able to be adapted without too much trouble - they seem to slip almost perfectly between the Chassis rail and the inner guard sheet metal at the front - probably be pretty easy to drill through both and then |
-- It's good to honk in a Henry |
I have tramp rods fitted to my XD and they make the car alot better to drive. How much is the fine as a matter of interest?
TRamp rods also stop the diff from bouncing this happened in my EH and the bouncing causes axels to break over time. Or earlier if not lucky.
If its not broke it will be soon |
I have been looking for factory tramp rods on ebay for the last couple of years and they seem to go for about $150-$250.The reason I've never actually bought any is I was'nt sure how effective they would be.My xa hardtop did have the standard springs(3 or
I was given a set of xagt tramp rods, they came with the l brackets. Now will these fit my landau? (with out the brackets)High steve did that box end up coming back?
c.rice |
c.rice |
