Joined: 17/02/2023(UTC) Posts: 16 ![Australia Australia]() Location: Queensland Thanks: 2 times
Hi all I would like some help if anyone knows. I've got a HK monaro and I would like to know what month and year the car was built I will provide body number.. HK81837 27231M THANKS DIMI Edited by user Thursday, 29 June 2023 3:49:26 PM(UTC)
| Reason: Not specified
You need the PSN and chassis number as well. |
Where can I find the PSN number and the chassis number also....thanks for before HK
Chassis number is on the firewall. PSN is the end of the VIN. |
Τhank you very much HK. Ill find them and get back to you here so I can get some answers of you.. Thanks once again
Hi HK For security reason is it ok to put the tags here numbers to find out the details of the car..please let me know.. Dimi
I got the details you asked for .. Or better PM ...thanks HK
I don’t respond to questions via PM. Only help in public domain. You can thank a foolish person in WA, but that is how it is. |
Hi HK Thanks for getting back to me and sorry for earlier message I didn't know it's my first time here.. I've got everything you asked for. BODY HK81837 27231M
PSN 27391M
VIN 81837K J133355
THANK YOU... Hopefully I can get month and year of this car. Dimi
You didn't do anything wrong, just letting you know that I don't respond to PM's for vehicle identification or similar help.
PSN is J133355 Chassis number is HK27391M
What is the TRIM line on the body tag?
Will get back to you on timeframe. |
HK I don't understand trim line... I have given you everything what I wrote down before from the tags and on the body stamp Edited by user Friday, 30 June 2023 12:04:29 PM(UTC)
Hi HK Im not sure by body line But the interior colour is 1153 10X Hope that will help you
1153 is Bright Blue Metallic paint. 10X is black interior.
Will be back with a build timeframe for you. |
HK Thank you very much for your help...
Thanks: 3 times Was thanked: 45 time(s) in 44 post(s)
If it is fairly original and complete you will find date codes on various compenents like the steering box an eg of the format- 23H8 (23 Aug 68) for HK series . The dates on the compenents will usually be a week to a month before the date of completion of the car. Edited by user Sunday, 2 July 2023 11:29:36 AM(UTC)
 1 user thanked Sandaro for this useful post.
Approx timeframe is the end of August 1968. This was a known car and has known idiosyncrasies with its ID plates, if you have the car you will spot what that is. If it doesn’t have its original engine it is hard to know what it was as Dandenong cars at this time are wierd. |
Hi Hk
Thank you for your message but I don't understand what you mean what you write down...its like a puzzle that I don't understand. What do you mean by well known car...about idiosyncrasies the ID plates and motor ???
Ill hear from you soon Thank you
I didn't say well known. I said it was known, as in it is recorded as known and existed to be recorded in the last 30 years or so.
If you have the car you will understand the statement about the ID plates. If you don't then it doesn't matter.
I'd be able to almost certainly confirm if its engine is original but I cannot predict what its engine number might be as there is no known pattern for Dandenong at this time frame. |
Joined: 2/03/2005(UTC) Posts: 491 ![Australia Australia]() Thanks: 3 times Was thanked: 8 time(s) in 8 post(s)
HK, There was no known “pattern” for Dandenong engine numbers as they came from stock in between engines we loaded for interstate etc. AL.
