Joined: 28/05/2016(UTC) Posts: 44 ![Australia Australia]() Location: Sydney Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Whoever put these pivots in at the factory must have been a legend of dexterity and patience. I just spent 40 mins trying to get one in, with a new rubber, and had to call it quits until another day. And this was from under the dash through the vent!
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Same bloke that designed the factory air set up I reckon.
Thanks: 1 times Was thanked: 631 time(s) in 593 post(s)
They are both easy to do if put in at the stage of the vehicle assembly they were done originally! Just like brake boosters. |
Joined: 21/12/2018(UTC) Posts: 104 ![Australia Australia]() Location: SA Thanks: 29 times Was thanked: 15 time(s) in 15 post(s)
Not sure if it was on this site but someone listed this as one of the worst jobs on cars they had worked on, and I 100% agree.
I've done several of these. If you remove the vent it's not that bad.
Dr Terry |
Everything is out of the car - no vents or stuff to get in the way. I can get the two square-on bolts in but not the third angled one. Or just the angled bolt and not the two square-on ones. I'm starting to think the new rubber piece is cut incorrectly. It has a wedge shape to it - thicker on one side than the other.
