666 Offline
#1 Posted: : Saturday, 25 June 2005 4:10:52 AM(UTC)
666
Hi yall,
Nyone out there know?, Can a 6cyl b Beefed up to V8 Specs ?
(ie Change Front Shaft?, Clutch Pac?, Valve Body?, etc...).
NY good W/shops round Sydney ?
Also heard, but is it true , - a Gemeni Torque converter bolts straight up to give u 1400 Stall? T or F ?
666
666
#2 Posted : Saturday, 25 June 2005 4:35:17 AM(UTC)
Mt druitt automatics did mine never had a problem with it 4cyl torque converter does bolt up but im unsure about stall speed and internals may not be strong enough but they do use the casing for high stall had mine done by slingshot in girraween
#3 Posted : Saturday, 25 June 2005 6:48:24 AM(UTC)
Gemini gives about 2200-2400 stall speed. I suspect the V8 one would have around 1400-1500. Geminis are tough in 6 cyls not sure about 8s, if the convertor was modded I guess it would do.
This page was generated in 0.100 seconds.
