#1 Posted : Monday, 27 June 2005 7:51:41 AM(UTC)
Complete power windows, central locking & power mirrors setup out of a VL.
All window motors & mechanisms. Master switch & rear door switches.
All central lock solenoids, front door lock looms, AND all the sliding lock parts (so you can convert any VB-VK with pin type locks to central locking & sliding locks).
Power mirrors, the switch, and the control relays.
Also comes with a complete loom for the power options, original, untouched, and not cut in any way. This makes it plug & play in VLs fitted with the correct harness plugs in the main wiring looms.
This loom runs to all 4 doors, to the various switches & relays, and to the multi-pin plug found under the LH end of the dash in VLs.
Also included are the 3 relays, their holders, and the circuit breaker from within the fuse box - complete with the plug-in sub-loom.
This is "plug & play" into any VL Berlina, and possibly some SL/exec models if the plug for the sub looms is present in the harness.
These parts can also be fitted to any VB-VL, sedan or wagon, to convert it to power options. Wiring would need to be altered to make it work. I can make up a "plug & play" patch harness (for $50 extra) to suit any VB-VK so it works like factory - and all you need to hook up to is battery +, earth, and ignition +.
I will only sell it as a complete package. All motors work, and were running in the car before dismantling.
WILL NOT SEPERATE so don't bother PM'ing wanting just the switches.
Asking $400 for the complete package.
Located in Sydney. Will post to anywhere in Oz at buyers expense.
I can deliver to the southern 1/2 of the Sydney metro area (anywhere south of the M4), the Wollongong/Illawarra, or the southern highlands, but only in business hours, for $20.
Send me a PM or use the "send email" link in my profile.
