hi i'm in the process of rebuilding my hq, got a healthy 308 now to go into it, but allready looking for the future upgrades ! so i am starting to look out for vn injection at swapmeets etc ! wat do i need other then the obvious heads/cam/manifold/exhaust/computer/engine harnes/fuel pump ? is there anything thats particulary needed for the conversion from carb to injection i hav forgotten to add to my search list ? Regards:Gav
do you have hq gts stuff 4 me ?????
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
Map sensor, fuse box (or make your own relay setup), return line to tank, swirl pot (American Auto parts), low pressure fuel pump (to feed swirl pot). |
