Anyone done a LS1 chev transplant into a hx??
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Try Castle Auto Electrics in Victoria. They've done it to a HK/T/G which is harder than a HQ-WB anyway. I think you'll find the cost of the conversion and engine is worth twice as much as your HX. A better option is a VN-VSIII 5-litre, and if you want mor |
do's anyone know what is needed to fit a ls1 into a hq 1 tonner, and what changes are to be done etc......
ls1 transplant into hq on not hard,carby or injection,castle auto electrics 0354721442 ask for con,he will set you straight,mounts/adaptors in stock,extractors,sump(hump at back),in stock,as for radiator and hoses you will work that out.after all anyone c Edited by user Tuesday, 22 May 2007 7:41:31 AM(UTC)
| Reason: Not specified
thanks for the contact ill give them a call when everything is in the one place and i get a start, first thing is to clean the shed!!!!!
Have a look on australianLS1.forum
